Wolf1991 1 #1 Napisano 1 wrz 2016 23:01:51 (edytowane) Pomoże ktoś bo nie wiem które czujniki mam do wymiany dokładnie.. to są te w klamkach raczej tylko ile ich mam do wymiany? to są ostatnie błędy z keyless-a poniżej Zna ktoś nr tych czujników? Pozdrawiam ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ Component: BCM2 1.1 H02 0326 Revision: 00002001 Coding: 072200 Shop #: WSC 06335 000 00000 VCID: 020C12279D1CB62E4B-8056 Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K Component: FBSAUDIB8 IDG H38 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 5 Faults Found: 03286 - Sensor for Contact with Door Handle; Front Right 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 2 Fault Frequency: 32 Reset counter: 179 Mileage: 225921 km Time Indication: 0 Date: 2016.07.30 Time: 12:02:39 00192 - Rear Left Door Handle Touch Sensor (G417) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 3 Reset counter: 202 Mileage: 225284 km Time Indication: 0 Date: 2016.07.02 Time: 09:58:33 00193 - Rear Right Door Handle Touch Sensor (G418) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 12 Reset counter: 179 Mileage: 225920 km Time Indication: 0 Date: 2016.07.30 Time: 11:24:28 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 2 Fault Frequency: 6 Reset counter: 219 Mileage: 225900 km Time Indication: 0 Date: 2016.07.30 Time: 10:19:51 03286 - Sensor for Contact with Door Handle; Front Right 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 5 Reset counter: 179 Mileage: 225920 km Time Indication: 0 Date: 2016.07.30 Time: 11:24:28 ---------------------------------------------------------- Edytowane 2 wrz 2016 04:30:54 przez uszol Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
uszol 525 #2 Napisano 7 wrz 2016 22:12:16 (edytowane) Poczytaj, tutaj temat był wałkowany. Wg mnie padł lewy tylny i dlatego reszta sypie błędami. http://www.a5oc.com/forums/a5-general-q/21211-advanced-key-entry-problem.html Zadzwoń do ASO bo na rocznik od 2009 w zwyż ponoć była akcja na wymiane tych czujników. Jeden kosztuje w granicach 150-200zł. Może akurat się załapiesz Edytowane 7 wrz 2016 22:13:54 przez uszol Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Wolf1991 1 #3 Napisano 8 wrz 2016 05:01:56 6 godzin temu, uszol napisał: Poczytaj, tutaj temat był wałkowany. Wg mnie padł lewy tylny i dlatego reszta sypie błędami. http://www.a5oc.com/forums/a5-general-q/21211-advanced-key-entry-problem.html Zadzwoń do ASO bo na rocznik od 2009 w zwyż ponoć była akcja na wymiane tych czujników. Jeden kosztuje w granicach 150-200zł. Może akurat się załapiesz Dzięki kolego tak zrobię Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
